[official]qBittorrent 4.0.4 installer - Built with MSVC 2017
Link to 4.0.4 post-> index.php/topic,5460.msg27510.html#msg27510
*****ORIGINAL POST BELOW****
Here is qBittorrent 4.0.0 built with MSVC 2017.
4.0.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.1.5+git096ce54fae
Qt: 5.7.1 (32-bit) / 5.9.2 (64-bit)
Boost: 1.65.1
Boost: 1.65.1
Last edited by sledgehammer_999 on Fri Feb 16, 2018 2:09 am, edited 1 time in total.
RSS import?
Hi, first post!
I read that in version 4.0.0 the RSS system has been reworked. Will my current RSS setup be imported or lost when I upgrade?
Re: [official]qBittorrent 4.0.0 installer - Built with MSVC 2017
CHRISTMAS CAME EARLY!
Thanks for the update!
Not a big deal but meh.. I liked the old UI style better. Also, anyone else has their tray icon render poorly?
- shot.PNG (1.05 KiB) Viewed 51404 times
If there are issues with the new release please use this issue at Github instead clottering the forum so we have everything together:
https://github.com/qbittorrent/qBittorrent/issues/7741
Thanks.
Thanks.
I don't have a git account
My 4.0 works perfectly fine not sure what all the issues are from
Just in the past 2.5 months
I went from stable build, the installed the Beta everything went fine
Installed 4.0 last night with no problems
All I have to ask is 1 little issue why do the tracker fields still not have clickable columns for "Sorting"????
This feature does not work for me literally sick of clicking through trackers since I keep update list from a API and have at least 100 torrents going all the time...
BTW specs....
Windows 10 x64 Fall Creators update (freshly re-installed to it 2 weeks ago)
QBT x64 = v4.0.0
BTW specs....
QBT x64 = v4.0.0
[quote="Nemo"]
Thanks.
Take last reply back now I am seeing the issues after I did a system restart
man o man speed straight up then 0kb constanlty now and other reported issues
Thanks.
So, what's the reasoning behind not including search engines anymore?
You can still download the via the program. We just don't bundle them.So, what's the reasoning behind not including search engines anymore?
The plugins were moved to a separate repo, where other people have write permissions. And probably other plugins get accepted too.
It is a bit silly to bundle plugins when they could easily be outdated in a few days because someone fixed a bug in it upstream after the release.
[quote="sledgehammer_999"]You can still download the via the program. We just don't bundle them.
I know, but this kinda defeats its own purpose.
After downloading and installing all search plugins just now, I clicked on the "Check for updates" button..
This resulted in several search plugins updating themselves.
So, it turns out that the ones stored on qBittorrent's GitHub page is outdated just the same.
This also leads to the question; which repo does qBittorrent's update function actually connect to?
Thx a lot !
No lib1.1.x version ?
Congratulations guys!
I used to drag and drop magnet icons from torrent sites to the UI and it will grab it, now on drag and drop I get the torrent creator! :/
[quote="Rootax"]
Thx a lot !
Actually Sledgehammer999 made a mistake there. qBittorrent v4.0.0 does use libtorrent 1.1.5
Thx a lot !
[quote="Ahmed Badee"]
What are regressions....
Please, create a ticket about it on Github and it will get fixed ASAP. You cannot make progress without adding bugs - at least that's how it is in programming.
