QBT 3.1.8 on Linux Mint 17.1does not find anything on searches.
NoobZilla
Post by NoobZilla »
The search engines are enabled, the router is working and my internet connection is solid, and I left the QBT installation settings alone, so everything is sitting in its default configuration. I used the instructions at https://launchpad.net/~qbittorrent-team ... ent-stable to install QBT.
No matter what search term I use, the result always comes back "no results found."  I even tried the obvious ones like "Star Wars" or "Star Trek" and QBT still couldn't find them.  The search function works fine on Windows 10 (dual boot system) so I doubt it's the modem or router.
I can go to a site like Pirate Bay and open magnet links just fine. I just can't convince QBT to search.  I'm not sure what settings need to be adjusted. Any suggestions as to what I'm overlooking?
NoobZilla
Re: QBT 3.1.8 on Linux Mint 17.1does not find anything on searches.
Post by NoobZilla »
Praise to me! I have found the unanswerable question!
