Web API used to work fine but recently something has changed and when I attempt to for example curl "http://IP:port/version/qbittorrent" I get a 404 error.
Local bypass is enable and so is the internal network bypass.
edit: Looks like it has to do with authentication (might be an issue with bypass with webapi as it works fine for the gui). I'm able to get /login and /query to work but others such as /version/api, /version/qbittorrent do not.
I noticed that there are changes going on with the web api from looking at github.
4.1 alpha web api
4.1 alpha web api
