Has anyone successfully installed qbittorrent on Asus tinker board with TBOS v2.0.5 (Debian Stretch v9)?
I tried the following:
1/ update sources.list and also:
2/ sudo add-apt-repository ppa:qbittorrent-team/qbittorrent-stable
3/ sudo apt-get update
4/ sudo apt-get install qbittorrent
however, i get the following package error messages:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qbittorrent : Depends: libboost-system1.65.1 but it is not installable
Depends: libqt5core5a (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
Depends: libqt5gui5 (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
Depends: libqt5network5 (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
Depends: libtorrent-rasterbar9 (>= 1.1.6+git20180215.01c41fadcf+patched-configure) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I am no Linux guru, so any ideas? I did have it installed ok on previous tinker os versions.
Thanks for any help!
