I searched the forums and could not find a fix for this issue. Kindly direct me to a thread - if you know of one that includes a fix.
I've been using QBT for a couple of years (love it!) and the "Inhibit system sleep" function has always been hit and miss. After an update to version 4.1.2 (64-bit), it has completely stopped working.
Are there any known fixes for this?
Thanks in advance!
INFORMATION:
QBT is currently running with the Inhibit sleep on downloads and uploads options selected.
powercfg.exe /requests:
DISPLAY:
None.
SYSTEM:
None.
AWAYMODE:
None.
EXECUTION:
None.
PERFBOOST:
None.
System Specs:
I am running Windows 8.1 64-bit on AMD FX-9590 Vishera 8-Core 4.7GHz Processor | GIGABYTE GA-990FXA-UD3 AM3+ 990FX Motherboard | SAPPHIRE TRI-X OC Radeon R9 290X 4GB 512-Bit GDDR5 Video Card | G.SKILL Trident X Series 1866 16GB DDR3 RAM | CORSAIR Hydro H105 Liquid CPU Cooler
Inhibit system sleep - Not Working - v4.1.2 (64-bit)
Re: Inhibit system sleep - Not Working - v4.1.2 (64-bit)
I can see from numerous threads on the web that this is an age old problem that is not at the top of the programmer's to-fix list. It works sometimes, which is like not working at all; shame, as it is a much needed feature.
https://github.com/qbittorrent/qBittorrent/issues/7452
https://github.com/qbittorrent/qBittorrent/issues/7159
https://github.com/qbittorrent/qBittorrent/issues/7019
https://qbforums.shiki.hu/http://f.qbit ... ic.php?t=2
the list goes on and on and on and ........
I'm updating my own thread - in case anyone ever stumbles upon this. As of the current version 4.1.3, the inhibit sleep function appears to be working flawlessly 100% of the time - for the first time in its history.
In Windows you can run the following command to verify if qBittorrent is keeping your machine awake:
C:\Windows\System32\powercfg.exe /requests
It is not working for me in version 4.15 on Windows 10 v1809 and I find it increasingly annoying. It would be such a nice feature if it worked. Filezilla has the feature and it does work. I basically have to turn off auto-sleep when torrenting.
Wow. The captchas on this forum are a total nightmare. 10 minutes of captchas just to make this post.
