kstartupconfig4 does not "exist" or fails the error code is 127
yawnny
Post by yawnny »
Hey guys. I recently installed Qbittorrent and unpacked it using YaST (I'm using OpenSUSE). Now after the first computer restart after the install I get past the GRUB menu then i'm treated with this error message: kstartupconfig4 does not "exist" or fails the error code is 127. I've done tons of searching trying multiple options with no luck whatsoever. I've come down to a faulty package install.
my next step would be to uninstall the packages that came with qbittorrent when i downloaded it however I can't find which packages those are. Can someone please tell me the packages that came with qbittorrent or give anymore insight into what might be causing this problem? Thanks alot for the help.
Re: kstartupconfig4 does not "exist" or fails the error code is 127
Which openSUSE version do you use?
(I would like to check the package scripts...)
