I have a VPN tunnel to another country that supports TCP without any problems. UDP packets are not tunnelled.
When I enable the anonymous mode in QBittorent and send the peer data through the tunnnel,
does the untunneled DHT publish my real IP address, so I am no longer anonymous?
The documentation at this point is not accurate enough.
https://github.com/qbittorrent/qBittorr ... ymous-Mode
In the appendix are screenshots of my settings.
https://pasteboard.co/HI9KfER.png
https://pasteboard.co/HI9KAXT.png
Does DHT expose my real IP in anonymous mode?
Re: Does DHT expose my real IP in anonymous mode?
You're at least partially expose. As soon as you're UDP makes a connection, the other side knows you're IP because that's how else could the other side respond.
