Hi All,
Could you please tell me which is the best ever stable version of QB on Windows plateforms please?
I am currently running qbittorrent_3.1.10 i would like to upgrade
many thanks in advance
Best stable version of QB
Re: Best stable version of QB
in my experience, the latest v3.
everything went downhill with v4 - look at all the crash reports in github for v4
qBT v3.1.16 is certainly more stable than the qBT v3.4.0 betas and qBT v4.0.x versions as well.
qBT v4.1.3 is only starting to reach that level of stability, but there are some fixes it has that v3.1.16 sorely lacked.
EDIT: I meant v4.1.3 not v4.1.13 which doesn't exist...
Funny.. Anyway use whatever fits you but so you know; it isn't supported here anymore.
If it works for you use it.
