I did see this implemented long time ago in utorrent.
Basically you could install something called Magnet Handler and µTorrent Adder, that would allow you click on magnetic links (or even torrents if I remember well) on PC1 and as a action it would add the downloading instructions onto a utorrent installation on machine2 (on the same LAN).
It was basically a way to avoid lots of copy and paste from one device to another.
Does something like this exist for qbittorrent or could it be implemented?
I think lots of people like me don't do torrenting on the main device
Thanks!
send magnetic links to remote qbittorrent installation
Re: send magnetic links to remote qbittorrent installation
I should have done some homework before posting this.
I have found a Firefox extension called torrent control that does the job perfectly.
