I've been using qbittorrent for some 3 years now. Before that I was a slave to Limewire then uTorrent. The set-up was easy enough and I've never had a problem with download speeds. My problem is with seeding.
I like to give back more than I benefit from the downloads. Therefore I like to seed back to a factor of 3. I can find a lot of information on how to configure for fast downloads, but nothing for how to seed fast or with more than a couple of torrents. Once a download is completed, it usually goes into "Queued" status except for the odd one that will go on to seed. Even then the process is quite slow.
I used to have a share ratio of nearly 4.00, but it now sits at 2.04 (and falling). Obviously, the more I download without being able to seed back, the more the ratio will continue to fall.
I look forward to your answers & suggestions!
