One of my drives went offline and when I restarted it's trying to "recheck" all those torrents from that drive all at once. It's a large size of data with many large torrents. You can imagine how bad for the drive this is.
How do we fix this behavior. Pausing and starting them all used to work on an older version where it would then create a queue for one at a time, now it doesn't.
Also would be nice not to have to recheck files from a drive that went offline. This worked before too in the past.
Even better would be smart behavior to check one thing at a time per drive. So multiple drives = multiple checks at once, just one per drive at the same time. Would have to be some special code, since they all make up the same volume. Just an idea for the future.
Thanks
It wants to recheck everything at the same time.
