Not connectable...port forwarding???
Ninjadog
Post by Ninjadog »
Hello. I am on qBittorrent 3.3.16 Win 8. I am having an issue with a site that says I am not connectable and not able to seed torrents. I got some suggestions to port forward my router but I'm a little lost. It used to work fine and I'd rather find an easier solution so that's why I'm here.
This issue seemed to just start happening one day. I was on 4.13 and .14, and I also did get a new router. I think I remember it going fine after I got the router but I am unsure now. Anyway some more suggestions later I downgraded to 3.3.16 because it seems to be the release with no issues on the tracker site I use.
Just seeing if you guys have any idea on what ports to use or other settings I should change. At this point all I have changed are some port numbers.
If I force resume I can seed torrents but I am still not connectable. It looks like my firewall setting have a qBittorrent exception. Not sure what else to try here.
Thanks for any help.
