Can't connect to the swarm
DirtyOldMan
Post by DirtyOldMan »
My port is forwarded, I am connectable. I can't download anything for the last two days. Everything stalls no matter how many seeds there are. I use v4.1.4. My ISP is Comcast. Any ideas?
Switeck
Re: Can't connect to the swarm
Post by Switeck »
ComCast probably isn't blocking torrents but they may throttle in rare cases.
If you're using a VPN/proxy, that may be to blame.
Or your software firewall may have registered a qBitTorrent upgrade (to 4.1.4) as "now-infected, block internet access".
Software firewalls sometimes get very testy about changes to programs demanding internet access...and blocks them. So check your firewall settings.
There's problems with qBT's queuing, which can cause torrents to stall or remain queued when they shouldn't be. (I disabled queuing in qBT because of its bugs.)
Back up qBT's settings and resume files as well as all the .torrent files being used by qBT. Read here for how:
https://qbforums.shiki.hu/index.php/top ... l#msg13292 Backup qBT settings!
https://github.com/qbittorrent/qBittorr ... s_settings
...Then try with qBT in a "freshly installed" state by deleting the qBT settings files. Initially KEEP the resume files to see if qBT's settings and/or the resume files are to blame.
For more troubleshooting, we'll need this info:
https://github.com/qbittorrent/qBittorr ... ed'-issues
DirtyOldMan
Thank you! ;D
nateliv
Post by nateliv »
I am having issues as well. Very recently started. I think the 4.19 update and Windows Defender is blocking me.
I think Microsoft Windows Defender removes the SwarmCoordinator/Agent executable from \UE_4.19\Engine\Binaries\DotNET\. I have to restart my computer, disable Windows Defender Real Time Protection, verify the 4.19 installation which puts back the executables in place. Annoying.
Lucky Patcher 9Apps VidMate
