I Cannot REMOVE CHECK MARK in "Use UPnP / NAT-PMP port forwarding from my router" because it is grayed out.
Can you help?
Re: Cannot REMOVE CHECK MARK in "Use UPnP / NAT-PMP port forwarding from my router"
Does qBitTorrent show that it is doing UPnP in its logger window? (You may need to enable that window to see it!)
It's grayed out possibly because you have a VPN/proxy and/or have checked "Disable connections not supported by proxies" or "Enable anonymous mode" in qBT.
