Hello,
A while back, i reported an issue, about a memory leak while downloading large files.
To explain it quickly, my memory usage kept going up, until it reached 99% and the computer simply stoped working.
I tried multiple thing, with all the settings, cash related or not...
Anyway, none of that mattered, the issue was still there...
Just this morning i stumbled onto a fix, for a memory leak problem while using the steam link (issue i also have (Had)), since it looked similar to the issue i am (was) having with Qbittorent, i decided to give a go!
And it works !
The fix, is the following:
[align=center]The solution for this says to set 'Start' to 4 in your registry under
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Ndu\
And reboot[/align]
Don't know if it works for everyone, apprently that particular issue can be tied to MSI motherboard, anyway it's worth a try for those of you that have the same issue
Hope it helps !
