qBittorrent 32-bit vs 64-bit - Witch one to use?
KidGecko
Post by KidGecko »
I'm using Windows 10 64-bit and want to use qBittorrent v4.1.4 on it to seed around 100-150 active torrents.
I have 8 GB of Ram and a 1TB SATA-III 7200 RPM 64MB hard drive (no SSD...)
Witch version would be more suitable for the above configuration?
Thank you in advance.
Switeck
Re: qBittorrent 32-bit vs 64-bit - Witch one to use?
Post by Switeck »
Both 32-bit and 64-bit versions of qBT should be just fine.
KidGecko
Post by KidGecko »
[quote="Switeck"]
So the 64-bit version wouldn't be a resource hog on a x64 8GB system with more than a hundred active torrents? Active in seed mode i mean, i won't be DL/UL dousins of torrents in the same time.
Switeck
Post by Switeck »
Correct -- the 64bit one won't use significantly more ram UNLESS you set its cache higher than the 32bit one can be set for.
The 32bit one's cache WILL crash if set above ~1000 MB size.
The 64bit one's cache would probably crash your computer if set to its max size of 4096 MB if you had enough busy torrents and you were doing stuff to fill up the remaining 2 GB available ram.
KidGecko
Post by KidGecko »
So, for the 64-bit version, do i leave the cache at it's default value and only change it if i encounter problems then?  ???
Sorry, i'm really new at this cache thing, never had to configure it in µTorrent so i'm a bit clueless as to what value it should be (if changed).
Switeck
Post by Switeck »
qBT's default cache value should be -1 (auto-configure), which from what I've read is either 1/4th or 1/8th your total ram, or max cache size...whichever is smaller.
So even the qBT 64bit version's default cache size shouldn't be larger than 2 GB and should not need configuring.
KidGecko
Post by KidGecko »
@Switeck
Thank you for the clarification :)
[quote="arso96"]
Clearly it's not discouraged but I think it would be good to have an official 64bit vesion. It is not important from the standpoint of performance but if it is as advertising. There are many people who believe it's better even is no
I'm confused ???
Isn't the 64-bit installer hosted on the main page > Downloads containing an official 64-bit build?
mike20021969
Post by mike20021969 »
[quote="KidGecko"]
I'm confused ???[/quote]
Don't be - arso96 is the confused one. The 64-Bit is fine.
