New 1.415 version will not work or run with my PureVPN connection...
latheofheaven
Post by latheofheaven »
Hello!  For quite a while, I've been running an older version of QBT (3.4xx I think) and it has worked just fine, but lately I've been noticing VERY slow DL speeds.  So, I thought 'I bet there is a newer version' and there is, with 1.4.15 I believe being the newest stable version.
Well, unfortunately after upgrading to this version, when running PureVPN, which worked just fine before, now just shows the peer stats, but no nodes connected and no DL activity.
What do I do...?
Thanks!
Running Win8 / 8 Gigs memory
Switeck
Re: New 1.415 version will not work or run with my PureVPN connection...
Post by Switeck »
It may be the PureVPN has changed as well. Is the VPN node you're connected to "BitTorrent compatible"?
Is qBitTorrent set to the right network adapter? (It should be set to the virtual VPN one.)
