bind to interface - not working
rs232
Post by rs232 »
I'm trying to bind qbittorrent to the virtual VPN interface created by my VPN software/provider.
It seems like if I specify the "VPN" as bind to interface no transfer occurs (or peers are found).
Strangely enough it does work if I bind to the IP address of the interface instead.
is this a bug?
Thanks
there
Re: bind to interface - not working
Post by there »
it works for me. Since I have had the same issue as you I would suggest you change your server to another Country. You could try another port, but it is probably a country thing.
Your VPN provider may allow it, but someone else may block it. Had this quite a bit.
