Copying All Trackers from a Torrent?
Splat
Post by Splat »
Is it possible within qB to somehow copy all trackers from one torrent to be able to copy them to another? Thanks.
Re: Copying All Trackers from a Torrent?
No its not possible within qBittorrent but if you can copy them from a site, for example or somewhere else, then you can add them to the torrent you want. If none of these are possible you can type down the trackers in a notepad and copy them and add that way.
Splat
Post by Splat »
Ok, thank you.
