So, i updated to version 4.1.5. And now i cant access the WebUI in Firefox.
Well, if i restart the PC or reinstall Firefox, i can login and see the WebUI one time. If i close the browser and reopen it, i cant login anymore and have to redo the steps just described.
If i try to login after that first time the page just seems to reload, with the same loginpage.
Checking the logs it says login succesfully. (2019-03-06 22:33 - WebAPI login success. IP: ::ffff:xxx.xxx.x.xx)
If i login with the private mode in Firefox, i can login. And login in with Edge works fine.
Did not have this issue before upgrading qbittorrent.
As i said, i tried reinstalling Firefox. I've also tried clearing cache and every other thing i can "clear". I also manually tried deleting all "junk" that are left after a uninstall of firefox in userdata and windows program folders.
Anyone has any suggestions on what it might be?
Im starting to think its a bug in version 4.1.5 that manifests only when using Firefox, as i cant even login with a fresh firefox install after the first login.
