I recently installed qBittorrent and I've been having an issue where my downloads never start, and I know they are active. I tried uTorrent and Deluge and they work fine with the same torrents. The status says "Downloading ..." and the rest is 0. Here's today's execution log (I tried stuff so it may be long). I don't have VPN and am using IPv4 if it's relevant.
2019-03-06 11:06 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: TCP/8999
2019-03-06 11:06 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: UDP/8999
2019-03-06 10:59 PM - Options were saved successfully.
2019-03-06 10:59 PM - Anonymous mode [ON]
2019-03-06 10:58 PM - Python detected, executable name: 'python', version: 2.7.13
2019-03-06 10:57 PM - '2fe6882d1068649f59473f8caa9797155e11bffe' added to download list.
2019-03-06 10:56 PM - '2fe6882d1068649f59473f8caa9797155e11bffe' was removed from the transfer list but the files couldn't be deleted. Error: The operation completed successfully
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: TCP/8999
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: TCP/8999
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping failure, message: could not map port using UPnP: unknown UPnP error (-1)
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: UDP/8999
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/8999
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface :: port: TCP/8999
2019-03-06 10:24 PM - qBittorrent is trying to listen on any interface port: 8999
2019-03-06 10:24 PM - Options were saved successfully.
2019-03-06 10:24 PM - qBittorrent failed listening on interface 169.254.215.231 port: TCP/8999. Reason: The requested address is not valid in its context.
2019-03-06 10:24 PM - qBittorrent is trying to listen on interface 169.254.215.231 port: 8999
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 192.168.1.201 port: UDP/8999
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 192.168.1.201 port: TCP/8999
2019-03-06 10:24 PM - qBittorrent is trying to listen on interface 192.168.1.201 port: 8999
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: UDP/8999
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: UDP/8999
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: TCP/9069
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: UDP/9069
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: TCP/9069
2019-03-06 10:24 PM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: UDP/9069
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: UDP/9069
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/9069
2019-03-06 10:24 PM - qBittorrent is successfully listening on interface :: port: TCP/9069
2019-03-06 10:24 PM - qBittorrent is trying to listen on any interface port: 9069
2019-03-06 10:16 PM - '2fe6882d1068649f59473f8caa9797155e11bffe' added to download list.
