RSS Downloader Rules - disable once triggered
4tg8TvI
Post by 4tg8TvI »
setting up a rule using regex and was wondering about the following:
do the rules stay active after the have been triggered or do they continue to parse through the RSS after a hit is found causing the client to download everything matching pattern? ???
was wondering if I need to script this separately or is there a built in function for it?
Edit:
Ok, think I'm blind.  ::) "Ignore subsequent matches" is there.
