Shutdown Qbittorrent when disk space is low, windows version
markifi
Post by markifi »
1 you need Autohotkey for this
2 qBittorrent needs to be configured so it doesn't close to the system tray (options / behaviour / uncheck close qbittorrent  to notification area)
3 you should put this in your shell:startup in an .ahk file:
SetTimer, CheckDriveSpace, 120000 ;modify this number to a lower one if you have more than a 100 Mbit/s connection
CheckDriveSpace:
DriveSpaceFree, FreeSpace, c:\
If FreeSpace < 1000
	RunWait, cmd /c taskkill /im qbit*
	MsgBox, qBittorrent has been shut down automatically,`ncheck free space!
Else
	Return
Return
real simple. it can crash some of your torrents though, but that's better than the alternative of the certain catastrophic failure that qBittorrent does on running out of space. (at least it used to be like that)
