Automatically Opening Magnet Links with qBittorrent?.
I have recently reinstalled my Windows 10 Home OS. After installing qBittorrent v4.1.5 again I found that I now get a pop up in my Pale Moon 64bit browser with the link address which I then have to copy and paste into the add torrent link in the qBittorrent options and it will then download. Previously I would just have to click on the magnet link and it would automatically start up in qBittorrent. I had this happen years ago as well but cannot remember how to associate magnet links with qBittorrent in Windows 10. I looked in the default app settings in Win 10 but there is no entry for magnet links. Can anyone help me out here?.
Re: Automatically Opening Magnet Links with qBittorrent?.
In Pale Moon: Edit -> Preferences -> Applications -> find magnet and choose to open them with your client of choice
I'm having same problem, When I click on a Magnet, I get some warning pop.
This is the message , Client Failure, sorry no Magnet Link adding Support from Vuze Swing UI, try the vuze remote plugin , google chrome.
I am using windows 10 x64 with google chrome.
My version of Qbitt is 4.1.6.
Not using any fancy firewall, just standard windows, also antivirus is windows defender.
Not using vuze.
Does anyone have any help here.
Not using vuze.
