UDP Trackers (Timed Out)
UnbiasedManatee
Post by UnbiasedManatee »
I know it's pretty normal for trackers to time out but ALL udp trackers are _timing out_  on me (no connection refused or any other status, only time out); iIs this normal? My iptable rules allow all outgoing traffic implicitly. I also notice a ton of http trackers having the "connection refused" status - like 90% - you guys think that is normal?
Secondly, adding trackers does not automatically re-announce, is it normal to do a 'force recheck' ? The problem is with that is that it will go down the list and stop at the first tracker, even if it has only 1 peer, and skip the rest..
Thanks
UnbiasedManatee
Re: UDP Trackers (Timed Out)
Bump. Still have a time-out issue with UDP trackers.
Which version of qBittorrent are you using?
Which version of libtorrent do you have?
