installed new version but does not work
So I just upgraded to the new version 4.1.6 . It takes a little while to start but once everything comes up it automatically closes. I checked my processes and it's not there. I see the icon in my system tray but when I go to click it , it disappears. I am running windows 10.
Re: installed new version but does not work
Same here, Win10 Pro with 64bit qBitTorrent. Rolled back to 4.1.5 everything is working again.
It works fine on Windows XP and launches super quick
Thanks to the devs for the continued support
Post here:
https://github.com/qbittorrent/qBittorrent/issues
This is the issue you're talking about:
https://github.com/qbittorrent/qBittorrent/issues/10581
(I have the same
(I have the same
