Don't ask about this update again
FletcherV
Post by FletcherV »
This should be a pretty simple thing to do.
Every time I start your app, it asks me about the latest update, and I often say no.
Could you add a button or checkmark to that dialog so that it won't ask again until the NEXT update?
That would be great, thanks.
Re: Don't ask about this update again
Well, you can just disable "Check for updates" in advanced settings. ?
