qB v2.9.7 on Ubuntu Oneiric. All torrents pause, no activity.
RayArdia
Post by RayArdia »
qBittorrent has been working faultlessly for over a fortnight but has suddenly stopped working. All torrents are shown in red and are Paused.
Have tried reinstalling qB (without deleting the old installation) but problem continues.Restarts do nothing, every time I open qB the situation is as above.
What should I do?
Re: qB v2.9.7 on Ubuntu Oneiric. All torrents pause, no activity.
Which tracker are you using? (Just the url, name, whatever. Don't post the whole announce url!)
RayArdia
Post by RayArdia »
No tracker named. When I click on 'Trackers' nothing happens.
RayArdia
Post by RayArdia »
[quote="shiki"]
I appreciate your help Shiki and would like to answer the question - problem is I don't know how!
RayArdia
Post by RayArdia »
Just in case it helps, here are the last few entries in the Execution Log
21/03/2012 11:16:25 - '/home/ray/.local/share/data/qBittorrent/BT_backup/671cc89f26e20056d75302b84aaaaa57230fadfd.torrent' resumed. (fast resume)
21/03/2012 11:16:24 - Options were saved successfully.
21/03/2012 11:16:23 - Embedded Tracker [OFF]
21/03/2012 11:16:23 - Encryption support [ON]
21/03/2012 11:16:23 - Local Peer Discovery support [ON]
21/03/2012 11:16:23 - PeX support [ON]
21/03/2012 11:16:23 - DHT support [ON], port: UDP/6881
21/03/2012 11:16:23 - HTTP user agent is qBittorrent v2.9.7
21/03/2012 11:16:23 - UPnP / NAT-PMP support [ON]
21/03/2012 11:16:23 - qBittorrent is bound to port: TCP/6881
21/03/2012 11:16:23 - Peer ID: -qB2970-
RayArdia
Post by RayArdia »
[quote="RayArdia"]
[quote="shiki"]
May I ask for a little more help please?
Sorry. Uhm... where did you download the torrent? Which site? Domain? Search?
RayArdia
Post by RayArdia »
Downloaded via Ubuntu Software Centre
ironcross
Post by ironcross »
[quote="RayArdia"]
Shiki asks about the torrent file, not the torrent client.
RayArdia
Post by RayArdia »
Sorry to be dense but I can't answer that because all torrents which were downloading (and which in the past have shown their URLs) now just show paused.
BTW, I previously said that when I key 'Trackers', nothing happened. Now when  I key it I get a list as shown in screenshot.
Screenshot at 2012-03-24 20:34:53.png
ironcross
Post by ironcross »
Are you tried to recheck the torrents?
RayArdia
Post by RayArdia »
All torrents say 'Not contacted yet' Futher screenshot attached.
Screenshot at 2012-03-25 11:26:01.png
ironcross
Post by ironcross »
[quote="RayArdia"]
How about to try clean installation? Uninstall QB, delete all hidden folders and then make fresh install. But save your torrent files on some other place before to do that. Then you can add them again.
RayArdia
Post by RayArdia »
Tried that but I still have the same torrents (paused) listed. I think I may have failed to remove some hidden files.I am quite prpared to lose all the torrents currently in progress. Can you help me with the commands needed to fully remove qBittorrent and the to reinstall, either from the Ubuntu software centre or from a .tar source?
ironcross
Post by ironcross »
[quote="qBT FAQ at SourceForge.net"]Where does qBittorrent save its settings?
qBittorrent saves its preferences in ~/.config/qBittorrent/ folder. The .torrent files are stored in:
  • ~/.qBittorrent/ by qBittorrent < 2.1.0
  • ~/.local/share/data/qBittorrent/ by qBittorrent >= 2.1.0. This is the standard XDG data folder.
