No Search Plugins Will Install
SunMesa
Post by SunMesa »
Hello,
Total newbie here, please bear with me.
I have just installed qBittorrent v4.1.6 on a Windows 7 64-bit system which is running Python 3.6.1.
As there are no search plugins installed by default, I downloaded a number of them from the Wiki list of plugins for public sites, including:
Torrent Galaxy
Kickass
ETTV
Torrent9
as well as PirateBay directly from the engine master list.
When I try to install them via Search/Search Plugins/Install a New One, they all produce the same result, namely:
"Couldn't install [plugin name] search engine plugin. Plugin is not supported."
These downloads should all be compatible with my version of Python. Any idea where I'm going wrong?
Thanks for any info!
