4.1.7 Download keeps repeating over and over
bellyman69
Post by bellyman69 »
I was PM'ed by the torrent site advising me that I was eating mass data (~35GB) by downloading then redownloading the same torrent over and over from 0% (apparently two but specifically a 280MB torrent).
They locked me out and have reinstated me and after upgrading from 4.1.5 then from 4.1.6 to 4.1.7, the problem happened again. I then deleted the torrent (data/.torrent) and downloaded again from the site and drag&dropped into qB - the same exact problem again - therefore, reproduce-able.
I was able to downloaded the following week's torrent in qB with no issues and had been before this.
I am attempting to try Vuze (albeit they say that client is soon to be banned) ... but below is the log file (skinny as she is):
Note: don't want any backlash on ToU violations so I renamed it below (the quote versions '<<torrent_name>> looked the same but wouldn't rename - not bothering to see what the exact difference was)
(N) 2019-08-10T20:41:21 - Successfully moved torrent: <<torrent_name>> New path: U:\torr-comp-qt\
(N) 2019-08-10T20:41:23 - Successfully moved torrent: <<torrent_name>> New path: u:\qt\
(N) 2019-08-10T20:41:41 - '<<torrent_name>>' was removed from the transfer list and hard disk.
(N) 2019-08-10T20:42:12 - Download first and last piece first: Off, torrent: '<<torrent_name>>'
(N) 2019-08-10T20:42:12 - '<<torrent_name>>' added to download list.
(N) 2019-08-10T20:42:47 - Successfully moved torrent: <<torrent_name>> New path: U:\torr-comp-qt\
(N) 2019-08-10T20:42:48 - Successfully moved torrent: <<torrent_name>> New path: u:\qt\
(N) 2019-08-10T20:43:18 - '<<torrent_name>>' was removed from the transfer list and hard disk.
(N) 2019-08-10T20:45:03 - Download first and last piece first: Off, torrent: '<<torrent_name>>'
(N) 2019-08-10T20:45:03 - '<<torrent_name>>' added to download list.
(N) 2019-08-10T20:45:47 - Successfully moved torrent: <<torrent_name>> New path: U:\torr-comp-qt\
(N) 2019-08-10T20:45:49 - Successfully moved torrent: <<torrent_name>> New path: u:\qt\
There are no errors but for the red item which is odd; not sure if there is better logging - not seeing any. The torrent has 8 seeds and AFAIK I am alone with this issue.
When I googled the repeat download piece for qB - this has come up a number of times for years (5+) but not 100% sure if my problem is related.
Q1 - is there a way to turn off this automated cycle of redownloading instead of just failing?
Q2 - is there any other logging that could point out the problem?
Q3 - does anyone know what the problem is?
Now an extra tidbit - when I was advised of this I discovered I was very low on disk space; I was wondering if that was the cause (that it would fail with a disk space, then it would restart) but it did finish at 100% and restart from 0%. I have since freed up 600GB and again deleted the torrent completely. Or have I? Is there any known lingering of something related to this torrent that wasn't removed? I see under the appdata folder a cache folder.
I  love this client - using it with RSS feeds but this is dangerous. I went from a 2.2 ratio down to 1.7 ratio ... of which I have had there for a decade - and close to 1TB up. I am reading about this problem with qB and hoping there is some setting that is causing this.
thanks
belly
bellyman69
Re: 4.1.7 Download keeps repeating over and over
Was able to download with an old version of uTorrent without issue.
