UI lock password - how to remove/reset?
LaKoala
Post by LaKoala »
By accident, I set a password and now I don't know how to remove it. I tried to remove via %APPDATA%\qBittorrent\qbittorrent.ini, but that seems to work only for an older version? Hope you can help me, thanks.
LaKoala
Re: UI lock password - how to remove/reset?
Post by LaKoala »
Problem solved. Uninstalled once again, now with everything that there is to uninstall :)
mls
Post by mls »
Thank you LaKoala. This finally worked for me and I'm eternally grateful.
mls
