Speedlimits being ignored.
asundrus
Post by asundrus »
Hi.
I just updated to v2.9.7 and now my speedlimits seems to be ignored, no matter what I set them to, they are ignoring my settings, anyone else getting this?
loki
Re: Speedlimits being ignored.
Post by loki »
2.9.7 with libtorrent 0.16? This is probably uTP related.
In theory utp should be the best way to manage your speed limits, it should adjust speed upload or download if something else needs the bandwidth.
Now if you do scheduling and restrict further upload or download and it's ignoring these settings, I believe there could be a problem with the current implementation.
s4nder
Post by s4nder »
Check to see if "apply speed limits to uTP connections" is enabled in options.
asundrus
Post by asundrus »
It wasn't, but I ticked it now, so that should do it? i'll test it later, thanks for the replies.
*EDIT* The uTP did the trick.
