2.9.7 crashes when clicking on certain torrent
The_Great_Beast
Post by The_Great_Beast »
torrent file loads up fine, downloads fine, you just can't click on it it the gui or qbittorrent will crash.
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	qbittorrent.exe
  Application Version:	0.0.0.0
  Application Timestamp:	4f882f81
  Fault Module Name:	qbittorrent.exe
  Fault Module Version:	0.0.0.0
  Fault Module Timestamp:	4f882f81
  Exception Code:	c0000005
  Exception Offset:	005d681d
  OS Version:	6.1.7601.2.1.0.256.1
  Locale ID:	1033
  Additional Information 1:	0a9e
  Additional Information 2:	0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:	0a9e
  Additional Information 4:	0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
I've attatched the torrent file below.
Kooky.zip.torrent
(121.82 KiB) Downloaded 509 times
ironcross
Re: 2.9.7 crashes when clicking on certain torrent
Post by ironcross »
I added the torrent, it started downloading immediately and reached max speed in few seconds. No crash. I clicked on this torrent, on other torrents, looked at their info (General, Peers...), then deleted the torrent without a problem. Win 7 Pro SP1 32-bit.
Try to reset qBittorrent to default state by deleting qbittorrent.ini in his %appdata% folder.
If this don't help try clean install of the qBittorrent - deinstall, delete the %appdata% folder, then install again. And don't forget to copy your torrent files before to do that.
But first wait for other solutions from our users.
stihia
Post by stihia »
Deleting qbittorrent.ini doesn't help. Other thing that I've noticed is that qB crashes only with torrents that reach very fast very big download speeds. The torrent mentioned above is one of them, but one can also try Libre Office as example.
These are my crash details:
Problem signature:
  Locale ID: 1048
ironcross
Post by ironcross »
Libre Office can be downloaded directly from their official site without torrent.
stihia
Post by stihia »
Obviously. I've pointed Libre Office torrent download only to see if this download crashes too for other users.
Uninstalled 2.9.7 with Revo Uninstaller and installed qB 2.8.5. The problem seems to be solved.
ironcross
Post by ironcross »
No problem with the Libre Office torrent, but my max download speed is only 1 MiB/s (it reached it immediately). qBittorrent 2.9.7.
stihia
Post by stihia »
In this situation, maybe it would be useful the following information: the first version of qB installed on my computer was 2.9.3. When I uninstalled the program first time, in the Revo Uninstaller window were 2 entries: one for the 2.9.3 version and the other one for the 2.9.7 (upgrade). I uninstalled both of them in the advanced mode, first the 2.9.3. For the second one (version 2.9.7) I received an error message saying that the program is missing and cannot be uninstalled. Reboot, then clean install of 2.9.7 => same issue - crash on every torrent with speed over 1 MiB/s, regardless the torrent size and also the number of seeders/peers.
Uninstalled again 2.9.7 in advanced mode, reboot, then installed version 2.8.5.
Since yesterday, i've tested around 12-15 different torrents with high speeds (including Libre Office 2 or 3 times) but 2.8.5 never crashed. The speeds reached on these various torrents were between 1.2 - 6.8 MiB/s.
I will stick with 2.8.5 until a solution/fix will be found on this matter.
