No Connection
amason
No Connection
Post by amason »
Hello
At the bottom of the torrent it says "No connection...No direct connections. This may indicate network configuration problems" Any advice?
I have windows 7 and it downloaded very well
ironcross
Re: No Connection
Post by ironcross »
Restart your modem/router. Check the option UPnP/NAT-PNP in the Connection settings - it must be enabled. If the problem persists - try manually port forwarding in your modem/router control panel.
