Time to drop 32-bit windows support?
dreot
Post by dreot »
Isn't it time to drop the Windows 32-bit version support and only develop the 64-bit version?
Re: Time to drop 32-bit windows support?
Ah that's not how a software works.
You basically have a source code, and you just "compile" it to various architectures/systems/etc.
So it takes 0 effort to create a 64-bit and 32-bit binary as well once you get the ball rolling.
