FTP
WastedEffort
FTP
Post by WastedEffort »
Hi, fellows!
Can download folder be set to FTP location?
Win 10
Thank you!
Re: FTP
Hey!
If you mount the FTP location as Windows network share, MAYBE. Not too sure.
You can use winsshfs to mount SFTP as network drive, then download there.
Be careful, using qBittorrent like this is 10000% not supported. So if anything happens to your files, you can't really expect much support.
For me, winsshfs worked fine. Your mileage may vary.
