after install of 4.2.2 qbitorrent hangs
Lucky8Luc
Post by Lucky8Luc »
the process is "not responding" and the cpu usage is very high (both informations from the task manager)
I have also looked at it with the process explorer (sysinternals) and saw that qbittorrent sends a lot of SYN_SENT events, there is not an ESTABLISHED event after that... indeed at that point process explorer also hangs and needs to be 'killed'
Does anyone else have the same problem? and if so, how can I fix it?
Do I need to register a bug?
Thanks
Lucky8Luc
Re: after install of 4.2.2 qbitorrent hangs
Post by Lucky8Luc »
It seems I am the only one with this problem?
Lucky8Luc
Post by Lucky8Luc »
since version 4.2.3 works, i consider this request closed
Thanks for letting us know.
