# column missing in windows version
BionofBorsythe
Post by BionofBorsythe »
I run ubuntu 18.04 and the qbittorent client has a # column and the ability to change the order of queue for downloading torrents which works perfectly for me. I have installed (and deleted and reinstalled and reinstalled and deleted and ...) both the 32bit and 64bit version on Windows 10 Home 64bit and have neither the ability to add the # nor the # column. I do not have the arrows to move items up or down in the Q either. I have searched throught the settings and cannot find a way to enable this behaviour in the windows version (i admit i may be blind or stupid or both) Any help would be appreciated.
Re: # column missing in windows version
Interesting. If you right click the titlebar... like "Name", "Size", "Done" and such... and pick "#"... you still don't get that back?
BionofBorsythe
There is no # to select
BionofBorsythe
the linux version has it, windows does not weirdly
This is Windows 4.2.3 though... had it since forever...
swedishjeff
Post by swedishjeff »
I can confirm. I am running Windows 10 version 4.2.3, and I have the ability to hide/show the number column.
My friend (Windows 10, v4.2.3) does not.
If you disable queue the # column will be gone. If you enable queue the # column comes back. So it probably has something to do with the queue system.
tinstaafl
Post by tinstaafl »
This worked for me, I just set the maximums a little higher
vlab22
Post by vlab22 »
Nemo wrote: Fri Apr 17, 2020 9:44 pm If you disable queue the # column will be gone. If you enable queue the # column comes back. So it probably has something to do with the queue system.
It worked!
Tools -> Options -> BitTorrent -> Torrent Queueing
