I just downloaded the new Qbittorrent version
to replace the one I had installed.
Everything is fine but there's one thing that annoy me..
Whenever a new torrent is added to Qbittorrent
The main program window pops in (Ok) BUT another
window also pops in over the main one with the new torrent displayed !!
I could not find any way to get rid of this 'new torrent' poping window
and just keep the main window for the new added torrents.
Like the previous version I had.
Can you help me ?
Thanks
Jean-Pierre
Annoying 'new torrent' popup window.. Not able to just keep the main window.
Re: Annoying 'new torrent' popup window.. Not able to just keep the main window.
Welcome,
Can you explain it a bit more or put a screenshot of it? Thanks.
Check the attached snapshot file..
You will see a Popup window in front of the main Qbittorrent program.
Now the user must click Ok to close this window to get to the main program
running behind it..
There is no way in the preferences to avoid this 'front' window
poping on any new torrent added to the download list..
My previous QBittorrent program kept the main program on the screen
even with new torrents arriving.
running behind it..
- Popup window in front of main program.JPG (169.25 KiB) Viewed 1600 times
