Hi
please can anybody help with installation in cli on debian buster (armbian to be specific) ?
I would like if possible ton install (or compile if that's necessary although i never done a such thing) latest qbittorrent with webui or alternative, i read about bittorrent-nox maybe it's what i need ?
Thanks in advance
Help to install
Re: Help to install
Hi
It is not so easy to install the latest version on Debian Buster.
There are many errors when it comes to compiling.
And there are problems with qt5 the web interface is not always accessible.
The easiest way for Debian Buster
sudo apt update
sudo apt install qbittorrent qbittorrent-nox
sudo qbittorrent-nox
Then you go http://your-server-ip:8080 to login
Username: admin
Pass: adminadmin
Then change the standard port for the web interface
Change password and username
The paths to the storage folders are best set under
/ home / username / downloads/
/ home / username / incomplete/
Click on save.
cd /root/.config/qBittorrent
mkdir ssl
cd /root/.config/qBittorrent/ssl
openssl req -new -x509 -nodes -out server.crt -keyout server.key
You should now have two files in your ssl folder: server.crt server.key
copy and paste the key and certificate's contents into the respective fields of the webui.
You can use "cat" in your terminal to view the contents of the files:
cat server.key
cat server.crt
Now click save
You should now be able to log in to your qbittorrent web-server keeping in mind to change http to https and append the port number with a semicolon :
https://your-server-ip:portnumber
Create autostart for qBittorrent
crontab -e
Paste the following
@reboot /usr/bin/qbittorrent-nox
Save now
My english is not perfect i hope you understand everything
sudo apt update
Username: admin
Pass: adminadmin
Click on save.
mkdir ssl
cat server.key
cat server.crt
Now click save
crontab -e
Paste the following
Save now
