Bandwith allocation
firecore
Bandwith allocation
Post by firecore »
The only feature im missing is uTorrent ability to more bandwith to a specific torront. (all bandwith gets used for that first and the rest get diveded over the rest) Is there any chance we can have this on qbittorrent?
Thanks in advance
Re: Bandwith allocation
You can set speed cap if you want to the torrents, for example 250KB/s to one and the rest to the other. Is that what you mean? If so thats already possible. Right click the torrent and then download limit. The same can be done for upload speed.
superschnitzel
Post by superschnitzel »
So far, it's a bit annoying to use that slider every time. Would be nice to have predefined speed caps from a dropdown list.
loki
Post by loki »
[quote="superschnitzel"]
You can also click the box and type in any number... if anything it's more flexible the way it is now.
