Suddenly Getting: Errored: The System Cannot find the Path Specified
rkruz3
Post by rkruz3 »
I have been successfully torrenting for years and as recent as yesterday had successfull torrent. Suddenly Im getting this error from QBittorrent: "Errored: The System Cannot Find the Path Specified"
Ive tried several different torrents, turned off VPN, Firewall and Virus detection but still have the same error.
Any thoughts on whats going on?
THanks!
rkruz3
Re: Suddenly Getting: Errored: The System Cannot find the Path Specified
Post by rkruz3 »
Solved. The torrent was being written to a Network Attached Storage on my LAN. Apparently the NAS goes to sleep and does not wake up upon access. Once I woke up the NAS, Qbittorrent was able to save the file.
Robolov
Post by Robolov »
Thanks for letting us know where it came from! :)
QbitBugs2024
Post by QbitBugs2024 »
Same bug. I'm also using a Network Attached Storage; however, my NAS is not asleep.
Any suggestions?
Pepe
Post by Pepe »
I have the same issue, but I do not have a NAS...
I have the latest version of qbittorrent, and a reset op the programme and computer has not resolved this issue...
And, furthermore, one torrent seems to work, no problem, and the next, I get this "system cannot find the path specified" error again...
I'm at a loss, and would appreciate some advise!
JaxsonBeckett
Post by JaxsonBeckett »
That sounds frustrating! Connection issues can sometimes be caused by firewall settings or ISP restrictions. Have you checked if port forwarding is properly configured? Hope you find a fix soon, let us know what works for you! I was in the final stages of writing my dissertation, but I was stuck and running out of time. I decided to use Academized here https://academized.com/cheap-dissertation cheap dissertation service to help me finish it. The process was smooth, and the writer was professional. The dissertation was well-researched, well-written, and met all my academic requirements. The best part was that it didn’t cost a fortune! I highly recommend Academized if you’re looking for quality dissertation help on a budget.
