[SOLVED] Setting Which Make It Shows When qbittorrent Started
zanshin777
Post by zanshin777 »
Is there such setting which make it shows when qbittorrent started? (30 min. ago, 1 hour ago, etc.)
Re: Setting Which Make It Shows When qbittorrent Started
View -> Log (you have to enable log once)
Then you can see the earliest message with timestamp -> when you started qbt.
zanshin777
Yes, there is a line at the most bottom which showing when qbittorrent started.
Thank you very much for the answer.
