Is there a way to force the tracker list to update. On several versions of qb when adding extra trackers to the list it stops updating the trackers. This was fixed by moving one tracker on the list up or down, but now I've installed qb on FreeNAS and I do not have the arrow on the right to move any of the trackers anymore. Is there a way around this?
As you can see from the image, under the column "Tier" all of them are 0 and when you move one of the trackers up or down it used to fix this issue.
