Avast is showing botnet:blacklist hits on latest version
empuser
Post by empuser »
I have no idea about cyber-security so I have no idea what that means, but it's happening on both mine and my wife's computer.
thethriller
Re: Avast is showing botnet:blacklist hits on latest version
Post by thethriller »
Same here. Only seems to happen when the PC is idle (no popup warning while watching YouTube for instance.)
Could you share a screenshot of this error/"hit"? Thank you!
Maybe in the Avast app's logs? It should tell you what is it blocking...
thethriller
Multiple IP addresses and different ports, sometimes tcp, sometimes udp.
roba0665
Post by roba0665 »
I am also getting this error, started today..
v4.2.5 (64bit) Win10Pro
16sziszi
Post by 16sziszi »
I have the same problem since yesterday. https://prnt.sc/t9k7wh
The error url is 5.188.168.46 on 24008 TCP the infect is Botnet:Blacklist. I made it to exclusion, but its still poping up.
Could you guys open a Github ticket about this, and then the rest chime in too?
https://github.com/qbittorrent/qBittorrent/issues/new
I could open it myself but tickets require way more information (for good reason) than what I can read out from the posts here.
Thank you very much. By the way I use AVG, which is a rebranded Avast, and I do NOT get any type of blocks/messages on latest version.
Wermuttov
Post by Wermuttov »
it's not about the version, 4.1.6 - the same thing since June 30
thethriller
For whatever reason this has stopped happening as of yesterday (Wednseday 7/1) and haven't seen one since. If it happens again I can start a github ticket...
Has it stopped for everyone else as well?
malakyas
Post by malakyas »
it happens to me for a long time, with different versions. The vulnerability exploits of the application. Eset or malwarebytes also blocks these connections or alerts of it. now I use version 3.3.16 and it keeps happening. Is very annoying.
tranlated by google
a mi me pasa desde hace tiempo, con distintas versiones. tambien los aprovechamientos de vulnerabilidad de la aplicacion. Eset o malwarebytes bloquea estas conexiones o alerta de ello. ahora uso al version 3.3.16 y sigue pasando. Es muy molesto.
traducido por google
vulnerabilidad 2020-07-07.png (30.73 KiB) Viewed 4628 times
