Search function
Search function
I've been using qbittorrent for a 5+ years now and the search function was always great. What has been done to it? Or am I doing something wrong now? It used to open onto it's own tab, essentially. Now it's in a little box up the top and it doesn't seem to find anything
Re: Search function
Nothing changed... you just have to check for updates and then it works the same. (tried/tested on 4.2.5, Ubuntu 20.04)
Re: Search function
Thanks for your reply Peter. I have since discovered that Python was not installed. Not sure if that happened when it updated or win 10 had done something to it??
Re: Search function
Yeah Windows 10 offers this weird Python that it lets you download through the Windows Store.
I just usually go to Python's website, pick the x64 (64-bit) version for Windows and install it. Works like a charm.
