tcp listener not up
wconst
tcp listener not up
Post by wconst »
I have two problems
1.TCP listener does not up
2. and, the program freez when i opening a settings
port in the router is open
Re: tcp listener not up
Settings window should not freeze, that's just not normal.
Did it ever work before?
What Windows are you running? Windows 10?
Do you use any custom security software?
wconst
Post by wconst »
No. I don't use any security software. Windows Defender only.
Windows 10 (2004).
also freeze when opening the torrent download window. Sometimes (not always)
But, I more worries, that tcp-listener does not work. I don't connect to it even from telnet (localhost).
