qBittorrent 4.2.5 stopped searching
ocean750
Post by ocean750 »
I am using qBittorrent 4.2.5
haven't used it in some time.
when I opened it today and ran a search nothing happened.
What should I do ?
Thank you
Re: qBittorrent 4.2.5 stopped searching
Did you update Python on your computer by any chance?
ocean750
Post by ocean750 »
Peter wrote: Mon Aug 17, 2020 8:27 am Did you update Python on your computer by any chance?
actually, I am learning Python, so I have installed anaconda recently.
what should I do ?
Thank you
ocean750
Post by ocean750 »
Hi.
So what should I do in order to get it to work ?
It may have modifier your PATH and that caused some trouble. I'd check PATH.
ocean750
Post by ocean750 »
Thank you for replying.
How do I do that ?
Can you send a link that explains this issue ?
- https://www.architectryan.com/2018/08/3 ... indows-10/
- It should lead to the one that qBittorrent accepts. The order of these matters.
Honestly, I have NO idea which edition does qBittorrent installs on a PC when its installed.
Post your PATH variables here maybe? It's really tough to troubleshoot from such distance.
ocean750
Post by ocean750 »
Thanks for the link.
I have a taken 2 screen shots.
Yeah it seems like PyCharm added a new PATH there. You could try Edit that (so you can save it down to a .txt file as backup), then remove it. Reboot PC (or log out and log in) and see if that helped.
(For example I have Python 3.7 - last version - as first PATH entry.)
