Hello. I have been using qbittorrent for about 8 months. I have had no issues with it at all. I run a vpn on the pc that has qbittorrent and it has never been an issue.
It started 3 days ago and there has been no changes on pc or network.
Anything I try to download eventually errors out. Upon the start of the download, it shows the availability as 100% then quickly changes to 0.00%. No matter how many peers it shows, I get 0 peers. Today I have updated it, fully deleted and reinstalled. I still can not download anything.
I added a rule to the windows firewall to allow qbittorrent in and out on any protocol. I have upnp in the client set.
I am out of ideas.
Any help is appreciated.
Nothing downloads, 0.00 availability, 0(749)peers
Re: Nothing downloads, 0.00 availability, 0(749)peers
Are you by any chance using a SOCKS5 proxy server?
When I do this, I have to start the torrent withe the proxy set to "None" for it to start - then I can switch to SOCKS5.
Dunno why...
Dunno why...
Same here. Starts fast then trickles down to stalled. Possibly tied to the recent Windows update? I hadn't re-booted in awhile yesterday I got the auto-boot-update and it started failing after the reboot. I tried all the suggestions on-line with no success. I d/l'ed uTorrent and installed with the defaults and it runs fine and retrieves files successfully.
I've had a similar issue for the past few days, I've been using qBittorrent for months without issue but in the past few days I can't even connect. The connection status just says 'Offline' no matter what I do with VPNs, restarting, etc.
Do you mean you even cleared the settings before installing again?rehrnsberger wrote: Wed Sep 09, 2020 1:09 am Today I have updated it, fully deleted and reinstalled.
https://github.com/qbittorrent/qBittorr ... s_settings
Yesterday, I upgraded to 4.2.5 from 4.2.1. Same thing, runs for about 10-20 secs, then dies off to everything zero.
Reverted back to 4.2.1 and all is fine.
