I updated to the latest version of QBT. Now the torrents will often stop at 99.9% with infinite time to completion when there are 100's of seeds available.
Seems to be occurring with every torrent.
I'm not sure if it's the update or a setup thing.
Any experience with this issue?
Why is Torrent Always Stopping at 99.9%
Re: Why is Torrent Always Stopping at 99.9%
99.9% often happens when your anti-virus blocks/deleted a file and then qBittorrent cannot finish the download.
Click files on the bottom and see what's up with the file.
You may also enable Execution Log from the menu so you can see what's going on.
True, your antivirus is probably deleting/blocking the file. I have experienced this too several times. Disable antivirus and finish the download, but enabling your antivirus could delete the file again.Peter wrote: Sat Oct 24, 2020 7:16 pm 99.9% often happens when your anti-virus blocks/deleted a file and then qBittorrent cannot finish the download.
